ROCCAT Sota, surface issue?
5 Aug 2004
I've used cloth mats for years and generally buy a new 1 every year as they get grubby, dirty, you know.. but this year I went different and got a new mouse, the Kone+ so decided on the ROCCAT Sota for Xmas 2011.
Today however my Kone+ got the scroll glitch, and for some reason after opening the GUI it stopped, at the same time I noticed my Sota has a bulge.
After inspecting the mouse mat(Sota) I noticed how big the bulge is, right in the middle of the mat, where my hand rests, all the way to the bottom, where my wrist rests. I did not notice this when the mat was new.
Seems to me like it might be a heat transfer issue unsticking the surface? if you tap your back of your hand quite fast it sounds so much like when I rapidly tap my mouse mat, that's how big these pockets are.
But anyway, anyone else had issues with the Sota or read about any? I wonder what kind of RMA is possible with a mouse mat.
I had this issue with my Sota pad too :/ It just seems like the metal layer in the pad gets bent/stretched due to the weight/strain applied by your hand and mouse.
Wasn't really the most expensive mouse mat in the world at £11ish so I just replaced it personally but it was a bit annoying.
I now use my Kone+ on a Razer Scarab mat. It's a fair bit more expensive but it's the closest I could find to my old Razer mat which I wore out.
The construction of the mat seems to be rather vulnerable :/
