- 30 Jul 2007
Pride comes before a fall...
my rock solid machine (9x400Fsb) falls over very quickly when I put the side panel of the case on (1hr prime 95). the machine reboots everytime so far.
I would welcome some advice on how to fix.
What I know,
I have
G0, TRU 120 Extreme with Noctua 1200 rpm, Asus Formula X38, Antec P182, GTS512MB.
The Top and Rear Exhaust fans are on max.
The P182 has space for a 120mmm behind the HDD drive cage.
What I think
I think that that the orientation on the the noctua 120 (and the fact it doesnt point downwards like the stock cooler) and that it is high above the x38 means that x38 is not getting adequate cooling.
Ive think the board may be dodgy as even at stock values asus probe says it is overheating and then probe will stop reading temp / voltage values.
lapping cpu/tru wont help that much as it is presumably the case the which is over heating too much causing a non cpu component fail (given that it is stable without case).?
I could get a 120mm case fan for the vacant slot (but its more pointed towards gpu)
I could get a beefier cpu fan (but its higher than x38 anyways)
I could change the orientation on the cpu fan so its sucks accross x38 and pushes through cpu onto to top exhause fan. (but its higher)
any advice please.
Im going to prime 95 test at 400x6 stock cpu volts to lend weight that it is the x38 that is falling over.
What I know,
I have
What I think
any advice please.
