- 30 Nov 2010
- UK
Hi 8 Pack,
Hoping you could help me, I am trying to get my 2500k up to 4.8ghz. I have a watercooled system with fairly good temps so higher voltage should be ok? This cpu only needs to last for 12-18months then I will throw it in a htpc at stock speeds until it dies.
Have the following spec:
2500k
2x 4GB HyperX Genesis Grey DDR3 PC3-12800C9 1600MHz
Asus V Gene
I have tried the following settings as a starting point and then thought I would work my way down the voltage but even with the voltage at 1.45v it ran intel burn test once (max temp of 62) without fail and then when I ran it a second time it failed and with Prime 95 it's seconds before BSOD.
VCCSA Voltage: Auto
VCCIO Voltage: Auto
CPU PLL Voltage: 1.75v
Auto PLL Overvoltage: Enabled
PCH Voltage: Auto
VRM Frequency: 350
Duty Control: Extreme
Phase Control: Extreme
CPU Current Capability: 130%
CPU Multi 48 by each core
CPU BCLK: 100
DDR Frequency: 1600mhz
CPU voltage: 1.45v
DDR Voltage: 1.65v
DDR Timings: 9-9-9-27
Spread Spectrum: Disabled
LLC: Ultra High
C3 and C6 Report: Disabled
2500k
Asus V Gene
VCCSA Voltage: Auto
VCCIO Voltage: Auto
PCH Voltage: Auto
VRM Frequency: 350
CPU BCLK: 100
CPU voltage: 1.45v
DDR Voltage: 1.65v
LLC: Ultra High
