- 28 Mar 2006
During the recent heavy rain, I found that our roof (and flat roof) has a couple of issues. I think the main roof just needs a tile re-seating as I noticed a damp patch on our bedroom ceiling and when looking at the roof you can see a tile out of place.
Another issue that we found was that the flat roof appears to have also leaked. There was water coming in between where the flat roof joins onto the side of the house, so I thought that the flashing was damaged. Had a bloke out today to have a look and he's said the flat roof is in good condition and he can't see any reason why it would leak where it has (the roof felt is secured well onto the brickwork and there's no gaps) but he did say that there's what appears to be an old soil pipe (capped off) protruding from the roof and the sealing around the pipe is poor and needs re-fixing.
He's quoted us £750 plus VAT to re-seat a tile and to seal around the pipe with something called Rapid Roof (quick google says it's a liquid polymer). Now, correct me if i'm wrong but this price sounds way over the top, almost a quote as he doesn't want the work.
Is what i'm describing something that can be done DIY?
