- 23 May 2017
Hi everyone,
Thanks for helping with my concerns about fittings and sealing in a previous post.
I am now at the stage where I am connecting tubing to all of the fittings.
For the most part I am having no problems, but there are three connections I am having problems with.
The fitting in question is theBitspower G 1/4" Matte Black Triple Rotary 90 Degree G 1/4 Male to IG 1/4" Female Fitting (edit: sorry wrong one) Bitspower G1/4 Matte Black Dual Rotary 45-Degree Compression Fitting-ID 1/2" OD 3/4" WC-241-BP.
This is being used with 3M EKWB PrimoChill PrimoFlex™ Advanced LRT™ 19,1 / 12,7 mm, Bloodshed Red Tube.
Any ideas on what I can do to get these on? From researching people have suggested things such as warming the tube up by rolling it through finger and thumb as well as dipping it in warm water for a short period of time but so far these are not proving to be working, but if these are really the only ways I will have to try them again. Someone even went as far as to cut a good portion of the barb off to allow more clearance.
I have managed to get one of the 45 degree fittings to fit on without a problem and it just went on smoothly first time, but there are a few more fittings that won't screw down at all.
Researching this has also indicated that this is a common problem due to the nature of the version of this barb where the tube is attached: it has three flanges to give a better seal and also a shorter length of threaded area in which to screw the collar on, so it is extremely difficult to even begin threading. Apparently just getting even one or two turns onto the threading is enough as long as the collar doesn't come off when pulled.
Thanks everyone.
Thanks everyone.
