This weekend only we have fantastic pricing on Media :-
Datawrite Titanium DVD-R 16-Speed Branded VX2 - 50 Discs (TITANIU-01007) @ £4.99 inc VAT
Datawrite have been busy producing an updated version of their Titanium disc range, branded 'vx2'. Datawrite Titanium 16x Branded Blank DVD -R have been some of the best selling DVD in the UK and Europe and have proven to be hugely popular with OcUK customers.
The disc appearance hasn't changed much, with the tough titanium sandblast colour effect and classic Datawrite layout - logo at the top of the disc, disc information to the sides and a 4-lined area at the bottom to display the disc contents.
*****LOWEST PRICE IN THE UK*****
Datawrite Titanium vx2 16x Branded Blank DVD -R in Packs of 50 is a DVD recordable format. A DVD -R typically has a storage capacity of 4.71 GB (or 4.38 GiB). The larger storage capacity of a DVD -R compared to a CD -R is achieved through smaller pit size and smaller track pitch of the groove spiral which guides the laser beam. Consequently, more pits can be written on the same physical sized disc. In order to write smaller pits onto the recording dye layer a red laser beam with a wavelength of 640 nm (for general use recordable DVD, versus a wavelength of 780 nm for CD -R) is used in conjunction with a higher numerical aperture lens. Because of this shorter wavelength, DVD -R use different dyes from CD -R to properly absorb this wavelength.
Specifications :-
- Model Number: TITANIU-01007
- Product Name: DATAWRITE TITANIUM VX2 DVD-R 4.7GB 16x SPINDLE 50PK
- Package Type: Spindle
- Media Type: DVD-R
- Size: 4.7GB - 120min
- Speed: 16x
- Pack of: 50
- Special Features:
- High quality dye
- Improved long term performance
Only £4.99 inc VAT.
ORDER NOW
Mirror BluRay 4x Inkjet (10 Shrink) @ £8.80 inc VAT
Mirror 4x Blu-Ray Discs Full Face Inkjet Printable BD-R in 10 Cakebox is the next generation optical media format, from Mirror, designed for storing large amounts of data and High Definition, HD Video.
The new Mirror 4x Blu-Ray Discs Full Face Inkjet Printable BD-R in 10 Cakebox media will hold upto 25GB of data on a single layer. The Mirror 4x Blu-Ray Discs Full Face Inkjet Printable BD-R in 10 Cakebox disc can hold 25GB, which equates to that it can be used to record over 2 hours of HDTV.
These Blu Ray blank media discs have a full face printable surface suitable for use with a majority of disc surface printers, giving a professional feel and look to your project.
Brand: Mirror
Format: Blu-Ray
Capacity: 25GB Single Layer
Top Surface: Full Face Inkjet Printable
Packaging: 10 Discs in a Cakebox / Spindle Tub
Only £8.80 inc VAT.
ORDER NOW
Mirror D/L 8.5GB DVD+R 8x Inkjet (10 Shrink) @ £3.51 inc VAT
In common with other dual layer discs, these Mirror 8x Full Face Printable Dual Layer DVD+R DL in 10 Wrap have a data capacity of 8.5GB which equates to 240 minutes of video in standard play mode meaning you can fit even more of your favourite memories and yet still be assured that they are secure and protected.
Inkjet printable discs such as these enable you to add your own designs to the top surface with affordable machines such as the Epson R220 and R300 inkjet printers. Combine that with the ability of dual layer discs to hold nearly as much data as a commercially-pressed DVD and you have the ability to create high-spec movie and data discs.
DVD+R DL (DL stands for Dual Layer) also called DVD+R9 or Double Layer, is a derivative of the DVD+R format created by the DVD+RW Alliance. DVD+R Dual Layer discs employ two recordable dye layers, each capable of storing nearly the 4.7 GB capacity of a single layer DVD disc, almost doubling the total disc capacity to 8.55 GB (or 7.96 GiB). Discs can be read in many DVD devices (older units are less compatible) and can only be created using DVD+/-R Dual Layer and Super Multi drives. A dual layer disc differs from its usual DVD counterpart by employing a second physical layer within the disc itself. The drive with dual layer capability accesses the second layer by shining the laser through the first semi-transparent layer. DVD recordable discs supporting this technology are backward compatible with some existing DVD players and DVD-ROM drives. The recording speeds reached by dual layer media are still well below those of single layer media.
There are two modes for dual layer orientation, parallel track path (PTP) and Opposite Track Path (OTP). In PTP mode, used for DVD-ROM, both layers start recording at the inside diameter (ID) with the lead-in and end at the outside diameter (OD) with the lead-out. Sectors are sequenced from the beginning of the first layer to the end of the first layer, then the beginning of the second layer to the end of the second layer. In OTP mode, used for DVD-Video, the disk is recorded in the same physical way, but the sectors are sequenced from the beginning of the first layer to the end of the first layer, then the end of the second layer to the beginning of the second layer. In both modes, the layers share one lead-in and one lead-out.
Packaging: Wrap of 10 discs
Only £3.51 inc VAT.
ORDER NOW
Mirror C-DR 80min 52x Inkjet (50 Shrink) @ £5.99 inc VAT
The Mirror 52x 80 minute CD-R is the fastest disc available today. You can now record a CD in the time it takes to boil the kettle*. Our Grade A Mirror CD-R can store up to 700MB of data or 80 minutes of your favourite audio tracks.
The word CD-R stands for CD-Recordable. Mirror CD-R contain a layer of photo-sensitive organic polymer dye. When you record a CD-R, a laser is used to heat the dye layer, creating a permanent mark - this process is commonly called burning. These marks alter its reflective properties, as they are not as reflective as the untouched areas. This burning process is irreversible, therefore CD-R discs are WORM (Write Once Read Many). Once a CD-R discs has been recorded, the information cannot be erased making it incorruptible.
Mirror 52x 80 Minute Full-Face InkJet Printable CD-R feature an advanced Full-Face InkJet Printable face that has excellent ink absorption and a specially made quick drying surface. The Full-Face surface means that you can print onto the entire surface of the disc... even the hub!
Click Image to enlarge
Only £5.99 inc VAT.
ORDER NOW
Specifications :-
- Media Type: DVD-R
- Speed: 16x
- Pack of: 50
- Special Features:
- High quality dye
Only £4.99 inc VAT.
ORDER NOW
Brand: Mirror
Format: Blu-Ray
Only £8.80 inc VAT.
ORDER NOW
Only £3.51 inc VAT.
ORDER NOW
Only £5.99 inc VAT.
ORDER NOW
