I have a Linksys Wireless B router that seems to have a problem with the router part - it stops responding to ping after 2 minutes of use then I have to reboot the router, 2 minutes later it happens again.
I want to use it as a wireless access point and use my machine as a router. I'm currently using my PC with 2 network cards and a crossover cable to another PC, so windows ICS is working fine.
I connected the router to the 2nd network card, logged into it and disabled DHCP. This is where I get stuck. I'm using static IPs for all machines:
My machine:
network card 1 (connected directly to internet): obtained from ISP
network card 2 (connected to router): 192.168.1.2
router IP: 192.168.1.1
laptop IP: 192.168.1.3 and I've tried with gateway set to 192.168.1.1 and 192.168.1.2.
I cannot get the laptop to see the router. I get "limited connectivity" I think.
Am I missing something? There is very little info on this setup on the internet.
My machine:
