Router or Os problem ?
21 Jan 2010
Wales
Right here's the deal every time i switch off the router or reset it when it come's back on i have no internet access and an unidentified networks shows up !?
I can only rectify the problem if i use windows 7 restore your pc function
diagnosis cant resolve either...
I use sky broadband 20mb using there standard Netgear router...
i think it's my Os as my partner on her lappy can access the net when this happens to my desktop
any clues ?
cheers
no i don't use the cmd at all repair or diagnose problems dont work only thing that "fixes" it is a restore point...
side note i just had to use restore because of windows update allso messing the desktop connection up
Probably a driver issue for your NIC. If its attached to your motherboard go get the latest drivers.
I had serious issues with mine when I upgraded to Vista so just went and bought a £10 PCI NIC which I knew was supported.
