routing 2.1 sound from 360 through speaker card help
5 May 2004
have now realised my pc which is connected to the same monitor as 360 is always on when i play 360
im now getting fed up of routing round the back of the sub to swap cables
i hear theres a way you can route the sound from the 360 to the mic in on the soundcard and swap over from desktop
how do you do this please and what settings
card is the cheapy soundblaster audigy s/e 7.1 about 15 quid it was but it has mic in
many thanks
Err your wordings nasty. But what i do is use a xbox VGA cable which splits the sound into two cables, which are then combined by the adaptor so they can go into a line in.
Then you just need to "de-mute" the line in and, heypresto, sound through the computer.
You need a switch box. Or route audio from your sources to your TV, then audio out from your TV into your speakers. No need for audio switching, as your TV is doing it.
in what way is my wording nasty mate.
I have sorted this out now i just got a 2rca into 1 3.5mm adapter and plugged this into my line in on pc card.
thanks
