RTX 2070 as dedicated physX card?
You're not the first who's looked into second card for physx. I know I did, till the evidence out there finally satisfied me that it would be pointless.
james.miller raised a good point that I wouldn't have considered - whether physx for that is CPU or GPU, do you have a choice.
Yes :), you can select to have it either be automatically selected or what gpu/cpu to load it onto.
Right. I know you can do that in general. But I didn't know if you can do that for KF2. Do you mean in general or specifically for KF2?
To clarify using an example - you can set max pre-rendered frames to "1" in Nvidia Control Panel, but that doesn't mean some games won't ignore your setting. So even if you choose a GPU as physx, will KF2 actually adopt that setting.
