RTX 4090 coldfeet!
6 Jun 2005
Plymouth / Cambridge
Hi,
Looking here for more advice / sanity check than anything else i have a build pretty much fleshed out. With a 4090 at the heart of it. However with the fact that the 4090 hasn't moved in price and it takes up 48% of my budget is it worth getting a second hand "tide me over" card till the 50 series is out rather than spilling 1.6k. i could then sell the "tide me over" card and replace with a 50 series.
What are my reasons for this....
-- Getting a 3080 or somthing around £500 would save 1k to spend on a 50 series (recommendations welcome)
-- The 4090 only has DP 1.4a
-- 50 series rumored to be 70% faster than the 40 ( 5090 at least)
-- A cheaper card would do for now for what i need.
the rest of the build would be this
CaseLian Li O11 Air Mini - Black
CPURyzen 9 7950X
RAM 64gbG.Skill Trident Z5 NEO 64GB 6000MHz CL30 DDR5 Memory - AMD Expo
GCardGigabyte GeForce RTX 4090 Gaming OC 24GB
PWR SupplyMSI MPG A1000G PCIE5 UK PSU 1000W 80 Plus Gold Power Supply
CPU coolerNH-U12A chromax.black
MotherboardASUS ROG STRIX X670E-E
HDD M2 2tbSamsung 990 Pro 2TB M.2 2280 PCI-e 4.0 x4 NVMe 1.3c Solid State Drive
MOBO still TBD ASUS ROG STRIX X670E-E / MSI MPG X670E Carbon WiFi / Asrock B650E Taichi Lite
Thanks
P
atm i have a older 2k 144hz LG. but eventually would want a 4k or an ultra wide or 2x4k monitors
You've got to think the 5 series might be better but will likely be more expensive (again). There's always going to be new components just around the corner. The 4090 should last for years to come. If a cheaper card will do for now I'd probably go down that route instead of dropping 1.6k.
You can get gpus like the 4070/7800XT for just over £500 and they are around half the speed of a 4090, they won’t be good enough for 4k high refresh but they’ll be fine for 2k so I guess it depends on when you plan to upgrade the monitor. Also if you go on to sell one of those cards and get a 5090 then you’ll only lose a couple of hundred quid at most.
have just read that the 50 series looks to be 2025 with the new road map. maybe that is to long. I was hoping for 2024.
I kind of wish I had gone for the 4090 at launch now but as the price hasn't dropped I don't think i could pay full price now a year later. i managed to get a 4080 under £800 6 months ago so OK for now.
I will definitely buy a 5090 at launch this time if its a similar price as it may be the last top tier graphics card for years the way AI is going.
If the 5090 wasn't coming out till ETA 2025, i would have waited for it but to wait nearly 2 years for something to come out and have something tide me over for that period is not gonna fair well. Get the 4090 and be done with it and just be happy that it'll pretty much play anything you throw at it and content/3D creation.
You can always wait. Or you can buy now and start working and having fun. But the 50 series cards are due in 2025, not 2024; Nvidia are moving to a 3 year cycle. Given your other uses and their love of VRAM, I think your GPU selection is restricted to the 4090, 3090, 3090 Ti, and the RX 7900XTX. Which you should get depends upon the value you place on RT and (in gaming) DLSS.
Nope. Just get the 4090. 5xxx series is 2025 material so unless you are a patient bear…
Plus 4090 might seem overkill for 1440p 144 hz, however if you plan on playing Rt heavy games like cyberpunk, alan wake II and who knows what else until 2025 then it’s pretty much the only option to have good performance with no/least visual compromises.
Personally i got the 4090 and while i had some doubts before… after buying and using it for several months now i have no regrets. I know that if i got anything less i would have been dissatisfied 100%.
nd the RX 7900XTX
Unfortunatly AMD support for content creators like myself is far behind Nvidia atm. so really my only option is a Nvidia card. This is a shame as i am growing in fondness for the team Red & Blue cards.
