RTX 5080 Return faulty?
28 Jan 2011
Hey guys,
i thought i had the issue sorted, but no.. mega stutters, almost unplayable, single player or multiplayer..
happens bad on Six Days In Fellujah, Elden Ring and Sniper Elite..
Up to date drivers, CPU and GPU temps are fine..
Is this a 50 series card problem or do I have a dudd here?
i have a 7800X3D , Palit Gaming Pro 5080, 64gb RAM and im at 4K with a 40Hz monitor.
I'm going to assume you meant 60hz. :p
What settings are you using, and are you monitoring frames etc via any method? If not try configuring MSI Afterburner to give you an OSD for testing purposes, also run something like LatencyMon to see if there's any underlying issues elsewhere. The 5080 is a good card but depending on the game and settings it might not the best at 4K. Even with upscaling tech such as DLSS on some titles you might have problems, but it should be able to give you a solid 60fps if things are being set up right.
What settings are you using, and are you monitoring frames etc via any method? If not try configuring MSI Afterburner to give you an OSD for testing purposes, the 5080 is a good card but depending on the game and settings it might not the best at 4K. Even with upscaling tech such as DLSS on some titles you might have problems, but it should be able to give you a solid 60fps if things are being set up right.
sorry I meant 240Hz.
That might be your issue, try looking up the driver version and those games you're playing. If the issue is widespread, it'll appear quickly.
What changed?
thanks.
Nothing changed, I just didnt give the game test long enough to find teh extensive stuttering.
What FPS are you getting generally? - If it's bouncing off of your max on CPU (or both) it may be causing stuttering.
If possible, cap fps to 120 or so and see if you still have the same issue
Ah ok.. I haven't played elden ring but 60 should be acheivable on most things with a 7800x3d.... I don't have any further suggestions if CPU isn't at 100%.
As Tetras suggested though, I'd definitely try several drivers over the last year or so, while nV are generally ok, I've heard bad things about their drivers in the last few months!
Also, if it's your GPU dropping the ball, GPU-z may give you some indication (there's sensor for performance limit or something like that - it'll indicate whther it's power, clock or underutilisation etc...)
