Hi.
I'm getting a 5090 soon and I was checking the models I like the most between the ones that show up every now and then.
So far I'll decide for one of this two:
- MSI 5090 Suprim Liquid SOC. The fact of throwing out of the case up to 600w of heat from the GPU is a good thing. It's quiet and temps are very good both Vram and GPU. Not so good is the pump and how will last.
- Asus 5090 Astral OC. It does throw the heat inside the case. I can try to change the fans set-up to minigate a bit this issue.
Good feature is the fact of letting you know something's bad with the power cable, It uses PTM7950 as thermal compound which is great and being an Air cooled card the temps seem to be good.
The Astral LC version is way more expensive and hard to find.
Which one do you think it's better? Or which one will you chose?
