Ruijie A.P Help
26 Jul 2017
Hey all, have sky fibre coming in @ approx 400-500mb when doing speedtest through wifi near the router, other areas are approx 30-40 due to distance so decieded to add some AP;s
Now have set it all up and its done via the following
SKy router - Patch Lead to TP-Link TL-SF1016DS (Normal Switch) - Patch Lead to MERCUSYS MS108GP (POE Switch) - Connected to 2 x Ap's
Also as above fom the normal swtich there is a wire to an oubuilding 4 way poe swtich which also has 1 x AP connected
Thing is im only getting approx 90mb out of each ap. Any idea plz
Thanks
TP-Link TL-SF1016DS is a 100 Mbps switch, which explains why you are only getting 90 Mbps (overheads).
You need a Gigabit switch, for example: https://www.overclockers.co.uk/tp-l...01000m-rj45-ports-plastic-case-nw-174-tp.html
Or cable directly to the PoE switch.
Literally I was thinking bypass switch and go direct from router to poe
Only strange thing is on the ruijie app it shows 2 x ap (Indoors ones) under ethernet status:
Lan: rate 100m
But the outbuilding a.p says
LAN: rate 1000m
Even though outdoor poe switch is also coming off off the normal switch for internet
