Ruined Torx head screw.
  • Thread starter Thread starter DM
  • Start date Start date
DM
DM
Permabanned
11 Jul 2009
West Kingsdown, Kent.
I have managed to chew up a torx head screw that is recessed in plastic and hard to get at, any suggestions?
Drill...but you may only be able to get the head out...which could prove more problematic. :p
Other than that I think you're a bit stuffed really.
Cant get a drill in there behind it, i think im ****ed.
I dont know why i even attempt these things instead of just paying someone.
Any photos of the mashup in question? To see what we have to work with?
I dont think i can even get a shot of it because its recessed.
This is all down to trying to change a steering wheel, that involves these 2 torx things at the back of the air bag if you get what i mean.
We cut new grooves in to the screw head when this happens with an elec saw and then use a flat screwdriver or an elec drill with a flat screwdriver on it (after a lot of wd40 and some banging with a chisel between the screw head and the hole). But i guess since you can't get a drill in there there is too little space to do that?
We cut new grooves in to the screw when this happens with an elec saw and then use a flat screwdriven or an elec drill with a flat screwdriver on it (after a lot of wd40 and some banging between the screw head and the hol)e. But i guess since you can't get a drill in there there is too little space to do that?
Sadly that wont work as there is no room to get in there.
Can you bang in a slightly larger torx/hex socket into the head, essentially creating new biting points for this inserted bit to grip onto?
Did that when getting my steering wheel off and worked a dream on a totally stuck torx bolt.
Maybe try a RIBE or polydrive bit of the same size and see if it gets better purchase.
Polydrive:
Torx:
purchase, someone dropped it into a conversation at a wedding I was at the other day and the world stopped for 7 seconds as I marvelled at his ability to call upon such extensive vocab.
I have developed a lot of good words/phrases for my chosen industry, if you sat in all of my presentations you would tire of them, but hopefully for a one off I might impress
Cheers for all the advice chaps.
Im thinking about admitting defeat now though, i really am useless at this sort of thing :(
worst case just drill it out and re-tap with a slightly larger bore
direct and forceful, or manly, ggggrrrrr
do it with your chest hair out and a utility belt for maximum effect
Oh yes i strode out to the barn this morning tools in hand,in a manly fashion, ready for another fantastic bit of Marks famous motoring DIY, i saw the wife and her 2 mates sniggering, but i wasnt deterred!
After 20 minutes of cursing i strode back indoors and slammed into me office, to ask on here.
Another fine days work, looking good!
as long as they don't know of your defeat you still hold the upper hand, just go outside and saw through some wood, then nail said wood onto something, then drill a screw into it and hang your utility belt on it.
trust me their pants will dampen :p
Haha I'd probably be the same, at the slightest problem when working on the car I ask for help from either my dad or from a couple of mates. My old man on the other hand is stubborn and won't stop until he has done what he wanted to, even if it takes him hours for a small little thing and lots and lots of cursing. And yeah the last resort is often simply drilling the bolt or screw out...
Too late, they know i have failed by the cursing.
The other give away was me ringing the mechanic in the village and asking him to come up.
Still we cant all be masters of the toolbox!!!
