- 14 Jul 2005
- Birmingham
My home office/gaming room is in the smallest bedroom upstairs. The route will be to drill a hole in the external wall just underneath the bedroom window, then run the cable externally along and down the wall to the other side of the house where the main router is located in the living room.
What do I need to do this job in terms of cable type, ethernet sockets, terminating kits etc? Is it sufficient to run a single cable or do I need two?
Thanks
Edit: the route shown roughly in red. Cable comes out of wall where the orange circle is, then comes down to ground level going underneath the bay window and into the living room on the left hand side of the photo:
Thanks
