run powershell script as administrator?
29 Jul 2003
hi
got a wee powershell script that enable IP to DHCP and its working when i copy the script to powershell with adminsitrator
i would like to make a script instead but it wouldnt let me run it.
$networkConfig = Get-WmiObject Win32_NetworkAdapterConfiguration -filter "ipenabled = 'true'"
$networkConfig.EnableDHCP()
$networkConfig.SetDNSServerSearchOrder()
ipconfig /registerdns
"*****************************************" | Out-File C:\Windows\COMPANY-staticIP.txt -Append
get-date | Out-File C:\Windows\COMPANY-staticIP.txt -Append
ipconfig /all | Out-File C:\Windows\COMPANY-staticIP.txt -Append
how to run the .ps1 with administrator? there is no option to right click -select run as adminstrator
thanks
I haven't tried it but what if you create a shortcut with the target set to:
Code:
powershell.exe -command "c:\path-to-script\script.ps1"
Then right click on the shortcut, go to Advanced and there should be an option to run that as administrator.
oops you are right.
got the administator option working now but the script is not doing anything, it doesnt set the IP to dhcp. which it does works when i copy/paste the script to powershell (run > cmd right click run as adminstrator)
oops you are right.
Not a powershell expert by any means but ive written a few scripts and normally get around this by setting the execution policy in the script.
Code:
PS C:\Users\infowp\Desktop> C:\Users\infowp\Desktop\dhcp3.ps1
File C:\Users\infowp\Desktop\dhcp3.ps1 cannot be loaded because running scripts is disabled on this system. For more information, see about_Execution_Policies at
https:/go.microsoft.com/fwlink/?LinkID=135170.
    + CategoryInfo          : SecurityError: (:) [], ParentContainsErrorRecordException
    + FullyQualifiedErrorId : UnauthorizedAccess
got this error message
PS C:\WINDOWS\system32> Get-ExecutionPolicy
Restricted
PS C:\WINDOWS\system32> Set-ExecutionPolicy unrestricted
Execution Policy Change
The execution policy helps protect you from scripts that you do not trust. Changing the execution policy might expose
you to the security risks described in the about_Execution_Policies help topic at
https:/go.microsoft.com/fwlink/?LinkID=135170. Do you want to change the execution policy?
[Y] Yes [A] Yes to All [N] No [L] No to All Suspend [?] Help (default is "N"):
