They might be a good price but consider when you do need to repair/replace. They ain't cheap!![]()
No the beading on the rim of a runflat wheel is different.
You definitely can put them on normal wheels but its a terrible idea.
You shouldn't fit them to normal wheels
p) perfectly fine, and will be absolutely fine.I have fitted normal tyres many many times without problem.
