Hi,
I have purchsed an Alpine F345 amplifier and an Alpine dual cone 4 ohm subwoofer. The amplifier will run two speakers on channel 3/4 at 2 ohms each but will only drive a 4 ohm load when the 3/4 outputs are bridged.
I can only get 8 ohms with the sub cones wired in series and 2 ohms with the sub cones wired in parallel.
The best option would have been to go for a 2 ohm per cone sub as I could have then run them in series to create a 4 ohm load but I'd rather keep the sub I have now. I have wired up the sub as a 2 ohm load and it works but will I cause any damage to the amplifier if I continue to run it in this configuration?
Also a quick question; when you bridge a load are you doubling the voltage across it?
TIA
TIA
