Hi
There is always a losses of quality when running cable long distances but 50m is not all that much try a wireless sender unit or get a gold plated cable
Dave
You need to balance it and then unbalance it at the other end. Boxes to do this are pretty cheap.
...balanced is the way to do it, which effectively cancels any noise as the noise gets induced 180 degrees out of phase on each signal wire... or sumthin like that![]()
Ahh thats it, used to build amps using balance transformers, I suspect there are much better active methods now though
