I'll let you know
I can play it maxed at the moment (with no AA), but it does get very laggy in places.
if you decide to add another 5850 to your motherboard with your existing 5850 occupying the x16 PCI-E slot and the other using the x4 slot, you should only be losing around 5% vs a full x16/x16 configuration.
I'll let you know
It'll be a bit more like 10-15% as I'm running 2 4870's here in x16/x4 and regularly see the x4 card hitting 99% usage in afterburner, but the x16 card is sitting somewhere around 70-85%.
This is with an i5 760@4ghz and at 1680x1050. If it was at a higher res I expect there would be an even bigger performance hit.
Plus it will also depend on how well crossfire is supported in the game that's being played, and I imagine the 5xxx series has slightly better scaling than the 4xxx cards.
Btw, what FPS are you currently getting from Crysis with your single GTX 460 maxed out and is it OC'd?
the first thing is I'm amazed how much hotter two cards run than one. I've had to remove the overclock, and my soundcard to keep the temperatures below 90 (never topped 75 with a single card).
Warhead ran perfectly at max settings with 4x AA, but I haven't benched it or run fraps yet.It'll be a bit more like 10-15% as I'm running 2 4870's here in x16/x4 and regularly see the x4 card hitting 99% usage in afterburner, but the x16 card is sitting somewhere around 70-85%.
My 460 was OC'd to 820/1900. Don't know the FPS as I've never actually measured it. I'd count it as just about playable though.
The other 460 arrived todaythe first thing is I'm amazed how much hotter two cards run than one. I've had to remove the overclock, and my soundcard to keep the temperatures below 90 (never topped 75 with a single card).
Had time for a quick run of Heaven, and a bit of Crysis Warhead after wrestling with driver problems for most of the evening. Ran Heaven at 1080p and default settings and got an average of 59fps on the first run, with a minimum of 29 and max of well over 100Warhead ran perfectly at max settings with 4x AA, but I haven't benched it or run fraps yet.
Should have time to do more later in the week (as long as the whole thing hasn't melted by then)
This is correct from what I have tested.
I tried my 6970 with a friends 6970 on his 1156 motherboard (x16 + x4) and the performance hit is definitely noticeable.
Heaven bench marks for x16 + x16 & x8 + x8 are usually around 2400+(based on the benchmarks I have seen done on most popular sites, including these forums too), where as x16 + x4 was around 2000 (for my own test on friends pc).
I think there is a greater difference in performance with regards to the lanes in this particular circumstance because the two cards required at least x8 speed bandwidth each to perform well.
I think this is probably why x8 + x8 performs similarly to full x16 + x16.
Perhaps it would be less noticeable for slower cards?
I also read from another forum something similar to what is being discussed here.
http://hardforum.com/showthread.php?t=1473990.
Hope this helps!
I can't believe you are hitting over 90 degrees wiith both cards in SLI.
What exact cards do you have as I remember reading that 460s with reference coolers tend to be among the best in terms of noise and temps?
Also what case are you using?
The performance seems epic, but I'm not sure if it's worth it from a noise and heat point of view. Any suggestions to lower either gratefully received. I downloaded the latest bios for the cards to see if that helps at all. I guess I probably need a chassis with better airflow, but I thought I'd finished spending money on it fi a bit.
When you said that you tried your 6970 with a friends 6970 on his 1156 motherboard (x16 + x4) and the performance hit was definitely noticeable,
were you talking about the noticable performance drop from just benchmarking or from actual games, as looking at the GTX 480 SLI x4/x4 benchmark from
Ok, so I've bodged a 75mm fan into the side panel of the case blowing directly onto the graphics cards. I've also taken out all the spare PCI blanking plates. It's now not going above 78 on the top card so I'm much happier. It's lots quieter too. Progress![]()
If I can move the cards on, I'll get one of the GTX 480's that are on offer at the moment and see how that goes.Not quite sure what's made the difference.
They're for sale now anyway! I've got the temperatures under control, but the noise is still a bit of a problem. I suspect my PSU isn't quite up to the job, as that's getting very hot and noisy as well, and I can't really afford to upgrade that at the moment. SLI hasn't turned out to be all I'd hopedIf I can move the cards on, I'll get one of the GTX 480's that are on offer at the moment and see how that goes.
A lot of the fan noise is the PSU, it's also creating lots of heat which is really not helping. The hot air coming from it was raising my CPU temperature by almost 10 degrees. I guess you learn to check your power requirements before you buy the hard way.
I basically have two options. Buy a decent 750W plus PSU, or sell both cards and get hold of a better single card with the money. I'd like to get the PSU but I suspect that's an expensive option.
