- 2 Dec 2006
Hey guys. Well I need some help as i've set up a server with mani admin and all that and it works fine but only over lan. Even with sv_lan 0. The reason being that I can't seem to get it to work with my internet ip and instead only works on 192.168.1.50:27016
When I add my external Ip 86.29.1.47 (using whatsmyip.com to find it) into the command line for starting the server it tells me that it can't allocate a port to that ip.
Suggestions?
:EDIT:
Also trying to use cmd via the command:
srcds.exe -console -game cstrike -tickrate 33 -ip 86.29.1.47 -port 27016 -maxplayers 20 +map de_dust2
gives me the same error and yes I was in the directory of srcds where my server files are.
Suggestions?
:EDIT:
