running dual OS, vista 64 and XP
29 Feb 2008
Hi, i am building a new pc and i am thinking of running dual OS - Vista x64 and XP, just wondering if this would be possible using an 80gig HDD (for the OS's) and a 500gig HDD for general storage?:confused:
Yes in a nutshell, as long as the HD is partioned properly, say 20 Gig for XP and the rest for Vista 64.
No, it will make things run much better actually... Windows on C: and everythign else on D:
20GB for Windowsand Vista on *** rest of the 80GB is a good idea too ,so do as the vicar says
From experience, and the fact im running your setup, there are a few things you need to be aware of.
Ive cut my 80GB HDD in half, 35 for XP and 35 for Vista, and that is absolutely fine. you might want to make the vista drive bigger, but not much.
Make sure you install XP FIRST and then install Vista. This way Vista picks up the XP boot option and adds it to the boot menu. If you do it the other way, XP doesnt recognise Vista, and getting it back is a b****!
If you are like me then you will probubly have the first half of your drive with XP, and the Second half Vista. In this setup, while in XP you can set the Vista drive to whatever you want (ive set mine to V: and ignore it), but when you are in Vista, as the boot information is stored on the XP drive, Vista will not let you change the letter. it will probubly get alocated D:, and thats what it will have to stay at.
All my documents are stored on another (200GB) HDD and you just make the XP 'My Documents' folder point to there, and make the Vista shortcuts point to the relivant folders.
There will be no performance hit on any OS, as they just ignore each other.
