Running it in is about how you drive, not how far you drive and is really a preference dictated by the company who provides your warranty.
I thought most cars these days were run in from the factory?
This.
A new car is ready to drive, by all means take it easy for 1000 miles or so but it doesn't need "running in"
This.
I could be totally wrong here but are you Tommy B? You both seem remarkably similar and you even registered the month after Tommy B stopped posting on here.
I could deny this but the truth is I was wondering how long it would be until someone realised. What on earth made you think that?
Thanks for the advice, I'll be sure to check out the handbook when it arrives.
It depends on the materials used, but most cars can be given plenty of stick from day one now.
Oil use can stay high for quite some time now the chemistry is so advanced, the Alfa twinnys are quite bad for it, sometimes you have to use a poorer oil for a while just to get the pistons to bed in.
