Running in low power mode?
3 Dec 2004
Hi all,
I was going to post this in the General section but figured I'd post here instead as it does involve the GFX card.
How many of you run your hardware at lowest settings/speed when desktop browsing and not game playing etc?
Is it best to have a profile in bios for low speed cpu voltage, cpu speed, ram voltage and vid voltage? I know a lot of you adjust you vid card settings in desktop, which is the best app to use for the 4850 and is it the same principle of just making a new profile?
I did have a low profile GFX setting when using my old x1800xt, but the card would often artifect when putting the settings from low -> high, even though I knew the card would support the settings. Is that a problem any of you get?
Thanks
