Hi pack,
Everything I've tried with this memory so far is boiling back to the likelihood my motherboard doesn't like it. Before I sell up and buy some other dimms I figured I'd better ask you first
Basically anything over 1600mhz with sa/vtt at 1.2v pll at 1.9v won't post, if I fire it up to sa/vtt 1.35-1.4v I can get post but memtest will instantly throw out a few thousand errors, even at 1760mhz 11-12-12-36-2T 180. Ddr voltage is at 1.675v. Everything is fine at stock 1600mhz cl11 1.35v in memtest.
So I'm left with either a sub timing causing issues (all auto just now) or the motherboard just doesn't like the memory. Bios is the latest 2.1 and I've had 2400mhz dimms running at 2440 cl11 previously with much lower sa/vtt.
Any ideas?
Any ideas?
