Running RAID for the first time
8 Apr 2011
London
Hey guys,
Ive recently acquired 2 128gb M4 SSDs and I would like to try RAID out.
I am also running 2x 2TB HD's seperately. What would I need to do to set both my SSDs up in raid. Is it basically plug in > change the sata option > done?
What benefits will raid give me?
Thanks guys
Set your controller to Raid then Hold Ctrl + i at post, it is simple to set up and it tells you how to do it. Check this out for stripe sizes and speeds, he has the same mobo and SSDs.
http://forums.overclockers.com.au/showthread.php?t=1010604
Using Raid you will not get TRIM so over time your performance will slowly decrease. When you have installed windows make sure you install Intel RST.
This is my single M4, if you look at that thread you can see the difference.
