Running two monitors with different refresh rates
22 Oct 2008
Lisburn
I've a 34" ultra wide at 144Hz and I want to stack it with a 27" 1080P 60Hz monitor. I've a 3070 GPU. What issues would I have if they are running different rates?
27 would be for email only and the 34" would be for work and gaming. I'm looking to stack them where the 27" is on top of the 34" on a single monitor stand.
Zilch, i have a 38 inch Ultrawide at 3840x1600 160hz and have a second monitor beside it being a 34 inch Ultrawide running at 3440x1440 60hz
Only real increase is a slight bump in power consumption on the GPU side as it's gotta display more information
Hi
You should have no issues running multi monitors, i am running a 38" 3840 x 1600 175hz and LG 4k 120hz OLED above it and it works well.
Windows key+P lets you select between monitor settings quickly like using 1st screen only or duplicate/extend / or just running the second screen on it's own.
It wont be a problem, to back up what others have said I've ran multiple monitors of varying resolutions and refresh rates for years without an issue.
That's on both AMD and Nvidia.
None, I've been running multiple monitors with vastly different refresh for years
as mentioned already, shouldnt have any issues. There have been rumours of some issues in the past, but I believe driver updates and newer cards in general work perfectly fine.
None. I have a 120 Hz 4k and two 60 Hz 4k monitors and it's not a problem.
now to find a stacked monitor stand that'll fit a 34" and a 27" :/
Let me know what you find. I have a Bracwiser and it barely copes with the weight of my 27" monitors.
