i know nothing about bodywork or paint etc so bear with me.
just had a peak under the golf, first time since the snow, although the car performed heroically, the ice/grit/salt has not passed without leaving a mark.
the car is low, quite stupidly low. the leading edge of the subframe has had a fair bit of paint removed. in some placed there is rust coming through. it generally looks a mess. one of the PAS pipes is externally corroded too.
i want to clean it up and apply a spray that will
A) stop the rust
B) give it a coating to protect it.
is there such a thing or is this a manual labour, wire brush it down and respray it, job
A) stop the rust
