I am unable to find any solid information on this.
Anyone know if the RX 480 is capable of running in 4-Way crossfire.
Cheers lads.
AMD said they wont put any stops to more than two GPUSSure isAMD said they wont put any stops to more than two GPUS
Haha, that's what I want to hear
I have four tasty PCI-E x16 slots on my motherboard and I have been contemplating on how to fill them, while on a budget.
Trifired 480s definitely is ok but I am still working on getting quadfire to work.
That sounds like progress!
What seems to be holding back quad-fire?
pretty sure some boxes had 2x CF on them; definitely a waste of time imo... (unless you are mining crypto coins or something)
*Edit* my rx480 sapphire box says upto 2 GPUs
I have no intention of using four of them in a gaming setup haha. I agree, in that sense it's a waste of time..
Rather, it it were possible, I would have them as an enthusiast setup. Benchmarks and the likes.
Although now that you mention mining, I may have other plans...
QuadFire is definitely supported on the RX 480.
That's the answer I was looking for
Is it supported straight out the box? Or do you need a specific driver?
