Looking for a new drill as mine packed in a few days ago (was given to me by a mate Bosch combi drill). I use Ryobi tools at work think there all pretty decent (especially as the batteries are universal) and are very well priced)
but whenever we get contractors in to do cabling put up com cabinets etc. they pretty much all use Dewalt and after speaking to some of them they say if your going to spend £150 ish on a drill go for Dewalt as they are superior.
was wondering on what people would recommend between the 2.
all I'm looking for is a combi drill with good battery life for no more then £200 with battery and charger included.
I'm looking to buy 1 in July as I'm moving house in 3 months and I'm going to need to run some cat5 cable around and whatever else needs doing
thanks in advance
thanks in advance
That specific set only has one battery though. You'll need to budget for a 2nd battery dependent on the usage it will get
. Also not brushless so runtimes are halved over a brushless tool. Well overpriced at £150 with 1x 3ah battery, should be more like £90.
