- 6 Jan 2013
- Rollergirl
I know there's a Ryzen 2 thread on the go, but feel this could do with a dedicated thread as there seems to be a bit of confusion regarding memory compatibility and motherboard requirements.
Basing the system around a 2700x, and I appreciate that the answer may not yet be clear until people get their hands on the hardware.
The motherboard question is based on the fact that X370 & X470 exist so should existing X370 users be updating the BIOS or buying a new board? Is it feasible to buy a X370 board if it's got the features you want over X470 choices? I'm also interested in knowing if a full ATX board will offer an advantage over smaller form factors when it comes to power delivery etc.. Personally, I'll be using a full custom water loop so I want to get the most from the CPU... does that have to be X470?
As for form factor choice, it seems to be ATX for the X370 or X470 boards because there's nothing available in micro-ATX, and ITX seems to be lacking in features if the end user wants to push an overclock? Why is there no micro-ATX availability for these boards?
- What is the best memory set to match with a 2700x?
- What is the best Motherboard in each form factor; ITX, mATX & ATX?
