I think its more likely the new 8+8 layout that's allowed the infinity fabric to go higher. 4+4+4+4 means more transfers across the fabric bus which I assume/guess is "worse" for high bus speeds. Whether that counts as an architecture change or not I have no idea, I'm just interested in the possibilities for performance increasingyes.. Infinity fabric increase is something I knew about.. I don't consider that a change in architecture though....
1usmus seems to think so and is apparently already coding CTR for it.I want to know if they've finally got per core overclocking working as was rumoured a few months ago.
That sounds very promising.1usmus seems to think so and is apparently already coding CTR for it.
https://twitter.com/1usmus/status/1311988058825293825
I think its more likely the new 8+8 layout that's allowed the infinity fabric to go higher. 4+4+4+4 means more transfers across the fabric bus which I assume/guess is "worse" for high bus speeds. Whether that counts as an architecture change or not I have no idea, I'm just interested in the possibilities for performance increasing.
Without per core overclocking then an 8+8 layout could actually be a limiting factor as now a cluster of 8 cores would be limited to the speed/voltage requirements of the lowest quality core instead of a cluster of 4 cores.
