Hi There,
I bought an 8pack AMD bundle setup in December 2020. Over the past couple of days the system has been auto powering down. Looking at it I can see that the temperatures are spiking over 107 degrees at random points and on medium load is reaching 75 to 90 degrees.
8Pack Elite Tier- Asus Crosshair Hero VIII X570 - AMD Ryzen 9
5900X @ 4.65GHz Overclocked Bundle
Operating System: Windows 10 Pro 64 bit
Language: English
BIOS: 2502 type UEFI
Processor AMD Ryzen 9 5900X 12-Core Processor 24 CPUs 4.6GHz
Memory 32768MB RAM
Available OS Memory 32676MB RAM
Page File 16751MB used 20787MB available
I have a NZXT Kraken X63 AIO CPU Water Cooler - 280mm which has previously worked fine. Temperatures run hot but not shutting down. Recent days it is clearly over heating and I am worried about causing damage.
The thing that worries me is that I have changed no settings but now during another normally hot summer (30c) this time around the system is not managing and is failing.
Does anyone have any advice?
Hardware monitor Nuvoton NCT6791D
Voltage 0 5.08 Volts [0x7F] (+5V)
Voltage 1 3.38 Volts [0xD3] (+3.3V)
Voltage 2 12.21 Volts [0xDA] (+12V)
Voltage 4 1.81 Volts [0x71] (+1.8V)
Voltage 5 1.30 Volts [0xA2] (VCORE)
Voltage 6 1.02 Volts [0x7F] (VIN6)
Voltage 7 1.45 Volts [0xB5] (DRAM)
Temperature 0 39 degC (102 degF) [0x27] (Mainboard)
Temperature 1 50 degC (122 degF) [0x32] (CPU)
Temperature 2 39 degC (102 degF) [0x27] (TMPIN2)
Temperature 3 44 degC (111 degF) [0x2C] (TMPIN3)
Temperature 4 21 degC (69 degF) [0x15] (TMPIN4)
Fan 0 1125 RPM [0x465] (Chassis #1)
Fan 1 1792 RPM [0x700] (CPU)
Fan 6 2800 RPM [0xAF0] (Chassis #6)
Language: English
Memory 32768MB RAM
