Ryzen 7 4800H TUF A17 - how hot should it be?
27 May 2020
Just got one of these laptops and it seems to be running quite hot - clocked the CPU at a max of 94C just playing the Sims, albeit with maxed-out settings (my daughter, honest :) !)! Seems to run at mid 70s just in general usage.
Is this normal? It is sitting on a flat wooden desk. We even elevated it slightly to help with air flow. The room is hot but still...
I think it is rated at up to 105C but if it is hitting 94 under fairly low usage I wonder how long the chip will last...maybe there are bios settings I should tweak?
So I had a look in the BIOS and there were no CPU performance options. I thought I would update to the latest version anyway - it's on v302 and the latest one on the Asus website is 304. The EZflash tool in the Bios had no Internet option (not sure why) so I downloaded the file and extracted it to a USB. The file is named "FA706IU-AS.304". Anyway, I've tried to get the EZflash to run the update a number of times and keep getting "selected file is not a proper Bios" message. I tried formatting the USB to FAT (apparently that can be an issue).
Any ideas? I read that these files are usually *.CAP - should I just rename it? I'm nervous of bricking the machine.
Just checked on my lad's Zephyrus and with 100% load across all cores the max temp was 82.2°C
Yeah, I think there was something up with that laptop, or it just isn't a great design. Given that I want to go 17" I think I might look at an intel laptop - the newer 10875H chip seems to be up there with the 4800H for gaming and there are more configs available...better screens and RTX cards.
After watching other reviews on Ryzen 7 laptops, it seems like they all run very hot. Another Dell G5 video shows the CPU running at 100° during stress testing and in the 90°s during gaming.
It's disappointing seeing as they are 7nm chips and theoretically should run cooler.
Like this one? https://www.youtube.com/watch?v=9456VN1fkQM&t=623s
I think this is pretty much what I was seeing with the TUF A17.
The 15" version looks similar: https://www.youtube.com/watch?v=R4dIw215_Gc
