Ryzen 7 5800X3D Temps
17 Feb 2009
Considering getting one of these CPUS
I have a Kraken 360 AIO which works nicely with the Ryzen 5 3600. By that I mean at idle the PC is literally silent.. Under full load Cinebench is never more than 70c, gaming is usually in the 50s. Liquid temps rarely go above 37c when gaming. ( set a custom curve myself )
Only concern I have of the 5800X3D is the higher temps, which then means having to ramp up my pump speed and fans somewhat ( I hate loud noises ). How much higher are they compared to a R5 3600?
Temps under load is not much of an issue because when gaming, the GPU fans drown out pump noise.. However idle temps when not gaming is the potential issue
Also. Will this cpu run fine with a B450 Tomahawk Max Msi ?
Thanks!
70c seems high for a 3600 with 360mm water cooling. The difference between a 65 and 95 watt AM4 chip is usually around 10c
Could be as my AIO is set to exhaust.
My pump and fans are also turned down low to reduce noise.
I thought full load 70c was alright.
Thanks!
I use the Kraken z73 with the 5800x3d, during idle or general use I have the fans at around 750-800rpm and pump at around 17xx rpm temps bounce around 40-45c
Cinebench multi run 79c , fans get to around 1000-1200rpm
Gaming is lower depends on the game
I use in Lian li Evo case total of 9 120mm fans
Rad at the top as exhaust
Cool thanks for the info. My setup is very similar, Kraken elite and Lian Li with 9 fans total.
Is your curve configured for liquid temps or the CPU temps ?
I find liquid temps much quieter and stable.
We have the same thinking :)
Liquid temp so don't get the ramping up and down helps with how Ryzen likes to randomly spike
The rest of the case fans I set curve according to the GPU temps
Still considering the 5700x as I've looked at some benchmarks for gaming and the performance at 1440p seems very similar. I heard however if I was to upgrade to a better GPU in future then the 5800X3D is a better option.
Thanks!
5800X3D Runs great on B450 Tomahawk Max, just update to the latest bios as its not natively compatible. Also enable KomboStrike in the BIOS which is a -30 offset and helps with heat.
Regarding the temperature and noise, the offset I mentioned helps with the temps and i have my AIO set to quiet pump speed (2520rpm) but maybe a slightly more aggressive overall fan profile than yourself and its reading about 32-33db at 12 inches away. Unless you have your pump speed set reaaaaally low, I dont notice mine, just the fans, and obviously the fans ramp up when gaming.
Idle I’m at 32C today and gaming I’ve not seen over 63-65C and im using the Lian Li Galahad 2 Trinity Performance 360 which has 3 fans exhausting on top in a Lancool III, 3 intake on front and 1 exhausting on rear. I also went from a 3600nonx to the 5800X3D and it was a hell of jump performance wise for me.
Think of the 5800X3D as the beta version of the 7800X3D where not all the bugs had been sorted out yet so regardless of what cooler you put it under its going to run hot. There are things you can do to mitigate the heat like for example if your motherboard has support for PBO curve optimizer in the bios then you can try setting an aggressive negative per core curve ( if not you can also do this in windows ) or you could also reduce the thermal throttling temperature via BIOS. You have to remember that the SKU that the X3D tech was added to ( 5800X ) was already by far the hottest of the Zen 3 chips and the 3D-Vcache reduces the heat transfer on top of that
Have kombo strike set to 3 in the bios, using a be quiet air cooler and the front of my case off as i have a small meshify compact case, my idle temps are around 30c and gaming under 70c always, mostly sits in the mid 60s when gaming.
Upgrading to the 5800x3d was the best thing i have done to my pc, i never thought upgrading a cpu would make so much difference, i came from a 3800x to this cpu
Got the CPU set up and the temps are fine so far, they are very similar to the 3600 but under full load 10c hotter ( 76c )
If I run cinebench and ryzen master, all cores get to 4.2ghz. Is there a way to check if it boosts to 4.5ghz somehow ? I have not enabled KomboStrike as it seems to be running alright
in NZXT it says Clock: 4450mhz ( at times )
In MSI Afterburner it says max: 4450mhz
Thanks
Thanks
Would use pbo2 tuner or if your mb has it kombo strike if i was you just to get the temps and power limit down, and 4450mhz is what it should be running at so thats all good :)
Yeah thanks mate.
I did KomboStrike to 3 and now in Ryzen Master all 8 cores reach 4450mhz rather than 4200mhz so definitely an increase there. Temps are about the same still for stress tests. After a 2 hour session of GTA 5 its in the mid-high 50s so I will leave it all as it is.
The temps are similar to my 3600 whilst gaming.
