Just built a new Ryzen rig:
Ryzen 5 1600
GSkill Ripjaw V 16Gb DDR4 3200Mhz 16-18-18-38
MSI X370 Gaming Plus motherboard
I'm all working, and have had the CPU upto about 3800 using Ryzen Master, so all OK there.
But I dont seem to be able to get the RAM to run at anything other than 1067Mhz.
If I increase the slider even slightly it just wont boot up.
I've even tried increasing the voltages a little (1.35v) but still no joy.
I also tried using the profiles in the BIOS and they also refused to boot.
And I've also tried setting the CPU back to stock and speeding up just the memory, but no good.
What am I doing wrong. Whilst I understand there were issues with memory and Ryzen I'm on the latest Bios and thought these had been ironed out now.
I bought the memory thinking it was samsung, which I've read seems to have the right compatibility, but on looking into it I think mine one of the few ripjaws that aren't samsung after all. Mine are Timing 16-18-18-38 , and I think the samsung ones are different.
I'm going to be using this with x-plane 11, which is very memory dependent (uses upto 16gb) so I think getting the clock speed up will be highly beneficial. Which of the components are likely to be causing the issue, or am I doing something wrong? If it is components I may try and see if I can change, especially if its the fault of the memory.
Could someone point me at the exact setting and/or voltages I need to be using to get the ram running at 3200 (or at least close to it)
Thanks
Ryzen 5 1600
Thanks
was it 2 or 3 weeks after iw picked up 3733 one this showed up if i knew id wait for it heh. Few times already i was on edge of selling 3733s on ebay and picking yhis kit up just to have a play with it. Also noticed You git 3866 kit coming in maan why i like playing with memories more than games lolol
