Is anyone able to explain how the clock generators work on some of motherboards did the memory? Does this has a negative impact on performance?
I.e. If I have one system running with the clock gen at 3200 memory, and another with the clock gen at 3200 memory, is the clock gen causing infinity fabric to be lower clocked internally or something?
I.e. is the use of the clock gen actually not improving performance as much as it should due to running externally, and not using it (if the same memory speed could be achieved) result in better performance?
I could have worded it a lot better.
