Ryzen upgrade
30 Dec 2004
London
Looking at moving from a 3570K, 16GB to Ryzen.
I am thinking of a 1700, and 16GB of Ram. I am not sure which RAM I should be selecting, can anyone help? I have read the thread for Ryzen. I'd like the cheapest, but fastest at the same time. In otherwords, I am not particularly interested in benchmark scores but if an extra £50 can get a noticeable real world difference (or it gives extra OC headroom in the future) for example then I'd think about that.
As for motherboard, I was thinking a Gigabyte Gaming 5? (~£150) ish?
Thanks
G.SKILL F4-3200C16D-16GTZR Trident Z RGB Series 16 GB (8 GB x 2) DDR4 3200 MHz PC4-25600 CL16 Dual Channel Memory Kit - Black with full length RGB LED light bar
£165.59 if you look around and aren't in a hurry (not in stock).
3200 is the sweet spot and ideally you want Samsung b-die for best comparability with ryzen.
The 8 pack pro is recommended a lot which is b-die.
My basket at Overclockers UK:
Total: £576.47 (includes shipping: £10.50)​
if your doing CAD or heavy CPU intense work then would push for the Aorus 5/k5 above as VRM will handle 100% load for long periods better, gaming doesn't put as much stress all the time
