More interesting results from Steve, he compared Ryzen 2600X and 2700X to Intel 7800K and 7820K at 4Ghz with 3200Mhz memory to see the IPC difference.
Before commenting please read what i'm saying.
Both these CPU's with their high core counts use different than standard ways to connect the cores to eachother, AMD call theirs "Infinity Fabric" Intel theirs "Mesh Interconnect", Both have a higher than normal Inter core latency which can make a small difference to the CPU's IPC, AMD have improved their inter core latency with Ryzen 2 and with that IPC.
It should be said, and i agree with Steve here, the Skylake-X CPU's do enjoy higher clock frequencies so keep that in mind when viewing this, this is purely academic.
On productivity Skylake-X win some, Ryzen win some, that is predictable, what isn't predictable was the gaming results, again this is something that one might automatically think Skylake-X walks away with across the board.
No, not so, Skylake-X starts well in AoTS beating Ryzen by about 10%, however in Assassins Creed 'Ultra Quality' while the 7800 is again about 10% faster than the 2600X the Ryzen 2700X beats out the 7820K by a small margin.
The next slide need some explaining as this is where i think Steve fails to understand what he is seeing, reducing the quality settings to High from Ultra the 2600X closes the gap to the 7800K, this is a falsehood, i have explained this in another thread, his reasoning is by reducing setting there is less work for the GPU to do so more work is loaded onto the CPU, what he doesn't realise is by doing this you also reduce the load on the CPU allowing weaker CPU's, in this case the 2600X to catchup.
Next BF1, Ultra Quality settings the 2600X and 2700X are about 10% ahead of the 7800K and 7820K.
BF1, Medium Settings, no Steve.
FC5, Ultra Settings, again Ryzen vs SkyLake-X is 10% ahead, another result for Ryzen.
Overall it looks like Ryzen's Infinity Fabric is better than Intel's Mesh Interconnect resulting in higher IPC in games, however none are as good as the Ring Bus on Coffeelake.
