Nah, Rover LT77 RWD box does the same - splash lubrication isn't enough to reach all the shafts and gear clusters and so it has a small input-driven pump that supplies the top of the box.
Tow one and it soon burns itself up.
I didn't know that S2000s used a similar principle (thought it would have long gone by now) so will bear that in mind!
Autoboxes usually can be towed for about 5 miles at under 30mph in emergency situations but that's it. Ideally not at all.
Getting the driven wheels off the ground is a dead easy solution
Someone posted an interesting link about running in. Basically did several tests 1 with running in and one not and the one that wasn't run in looked a lot better when they took it apart.
