S775 CPU fan pls help!
7 Feb 2007
I just discovered that my CPU cooler for my e6600 doesn't fit :( I was using a Zalman 9500S which is for AM2 chips - use to use it on my AM2 4200+... i'm gutted so I need a good cpu fan and not a noctua cant get them local were I live.
Well I have a Thermalright HR-05 on my North Bridge so I guess I need enough clearance for the CPU cooler. I was thinking Big Typhoon but it might not fit... other than that I'm open to any suggestions. My mobo is a Giga DS3P rev3.3b:)
WJA96 said:
Thermalright Ultra 120 would be my preferred option.
I 2nd that.
Also the ninja is worth considering, particularly as it comes with a fan which the ultra 120 does not.
Don't bother with the zalman 9700, the performance and the noise levels are inferior to the tower heatsinks such as those mentioned above. The performance of the big typhoon isn't great either.
The freezer 7 is excellent for the money.
Have a look here. They don't ship internationally so i don't think thats against the rules.
The OCZ vindicator that they have is identical to the scythe ninja i mentioned, and they also have the ultra 120.
