Believe it or not, you can ressurect some of these with damaged SMD resistors if you are lucky like me...
good news
all went welland used old fashoin stanley knife took abit of time but done it
temps have dropped sits idle now at around 30c with air (big typhoon)
some small probs :
forgot to take screen shot of b4 shot so cant compare temps!!
both cores idle at 28/30c but underload c1 sits 20c higher than c2 72/52c
is this something i should worry about, is it bcos its not even?
Is it possible to remove the IHS on phenoms in the same way described in this thread?
people with too much money do this stuff![]()
Quite the opposite. People with too much money just buy the fastest chip they can and run at stock. People with a little money buy a chip and then mess with it until it's faster than the most expensive stock chip.
So if the processing chip itself is that small why don't they make them bigger with more cores?
