Safari 5!
Probably one of the best editions. :D Along with fullscreen HTML5 video (currently supported on Vimeo) and Reader.
Really liking it so far, could possibly tempt me away from Chrome, especially when extensions start popping up. All I'm really missing at the moment is being able to search from the address bar and undo closed tab.
This update contains new features including:
Safari Reader: Click on the new Reader icon to view articles on the web in a single, clutter-free page.
Improved Performance: Safari 5 executes JavaScript up to 25% faster than Safari 4. Better page caching and DNS prefetching speed up browsing.
Bing Search Option: New Bing search option for Safari's Search Field, in addition to Google and Yahoo!.
Improved HTML5 support: Safari supports over a dozen new HTML5 features, including Geolocation, full screen for HTML5 video, closed captions for HTML5 video, new sectioning elements (article, aside, footer, header, hgroup, nav and section), HTML5 AJAX History, EventSource, WebSocket, HTML5 draggable attribute, HTML5 forms validation, and HTML5 Ruby.
Safari Developer Tools: A new Timeline Panel in the Web Inspector shows how Safari interacts with a website and identifies areas for optimization. New keyboard shortcuts make it faster to switch between panels.
Other improvements include:
Smarter Address Field: The Smart Address Field can now match text against the titles of webpages in History and Bookmarks, as well as any part of their URL.
Tabs Setting: Automatically open new webpages in tabs instead of in separate windows.
Hardware Acceleration for Windows: Use the power of the computer's graphics processor to smoothly display media and effects on PC as well as Mac.
Search History with Date: A new date indicator in Full History Search shows when webpages were viewed.
Top Sites/History Button: Switch easily between Top Sites and Full History Search with a new button that appears at the top of each view.
Private Browsing Icon: A “Private” icon appears in the Smart Address Field when Private Browsing is on. Click on the icon to turn off Private Browsing.
DNS Prefetching: Safari looks up the addresses of links on webpages and can load those pages faster.
Improved Page Caching: Safari can add additional types of webpages to the cache so they load quickly.
XSS Auditor: Safari can filter potentially malicious scripts used in cross-site scripting (XSS) attacks.
Improved JavaScript Support: Safari allows web applications that use JavaScript Object Notation (JSON) to run faster and more securely.
For more information about fixes that improve performance, stability and compatibility, please see: http://support.apple.com/kb/HT4134
For information on the security content of this update, please visit: http://support.apple.com/kb/HT1222
some people saying on macrumour forums that there are some big memory leaks ???
There are always memory leaks if you listen to them :o
I don't care for extensions, but I'll take a decent ad blocker if one arises..
EVH have you tried Glimmerblocker?
It works as a proxy rather than an extension/hack to the browser which in some respects is better (e.g. the upgrade to Safari 5 didn't break it).
Haven't used that Olly, but I swear by Adblock for Chrome (on Windows) so I'd be happy if it just got ported to Safari.
may seem daft why dont they update it for ipad and iphone etc? or is it different
Its different is the easy answer. A lot of the technology under the hood is the same so they're not that different. Safari Mobile gets updated which each OS change. So when iOS4 comes out that will have an updated version of Mobile Safari.
its so fast, though one thing i don't like is, they changed the blue in loading bar it looks lighter now? or less detailed and looks more like i'm running tiger. :eek:
its also on software update
