Hi all,
What is generally accepted as the max safe voltage for a 3700+? I've heard upto 1.55/1.6v is perfectly fine as long as the cooling surfices. Is this true? this rig runs 24/7 100% load and I'd like it to last 2/3 years without the cpu dying. Temps are under 46 load.
I was testing 2700MHz but can't even run super pi with 1.39v so I am thinking 2700 to be stable if it will be that is might require say 1.45-1.5v.
Thanks for any replies
