Safe Temps for a 7900GS
13 Apr 2006
What sort of temperatures are OK for one of these? Currently overclocking it a bit, also any tips on that would be handy, eg what clocks to go for etc.
If it is anything like the 6800series then anything up to around 85C should be fine as the old cards were only set to throttle when they reached 120C, Coolbits should be able to tell you the throttle temperature, if you then take off about 30C you reach a temperature that ought to be fine for normal use. :)
