Safe Temps for e6300
2 Oct 2006
I've got my e6300 at ~3ghz (7.0 x 430mhz) , and under load each core is around 66-67 degrees c. is this safe? and the cpu temp is 55c, measuring outside of the cores.
tuniq tower
thing is, i did a stress test on css with 1.86ghz, got 135fps (1440*900 all high), when i did it with 2.8ghz, i got the same fps, and its not the graphics card as my 3200 venice managed around 170, is there a way to set one core to css, all by itself?[
Hairboi said:
tuniq tower
Either you're using a silly amount of Vcore or your Tuniq is not on properly or faulty.
mine is around 32c idle and goes nowere past 56c using TAT or Orthos.
hey... its at 28c now :D but im sure my body temperature is as close and i cant feel my toes :eek:
using a freezer 7 pro btw
