Safely eject usb?
10 Jan 2012
Sunderland, UK
Recently got another 3tb hard drive to store my dvd/blue-ray rips on (DVD case clutter...no thanks)
On the old one (had it 2 years now)
Is there a easy way to eject specific drives?
Is what the normal eject thing shows, I can only eject both of them by clicking on eject expansion drive and not select between them, anyway around this? so I can specify which to eject?
They are plugged into the same USB port via a USB 3 hub, which I'm guessing is the problem....
