'Safely remove hardware' icon, how to remove?
18 Oct 2002
Amsterdam,The Netherlands
How do I remove the 'Safely remove hardware' icon from the taskbar?
It is there ever since I upgraded my harddisks to two ATA ones and I don't want to accidentally stop them.
you cant accidently stop them, and I dont think you can remove the icons.
If they are in use windows won't let yuo stop them anyway, so I don't see a real problem.
Having said that, its not exactly easy to accidentally open the 'safely remove hardware' window and accidentally stop something that you don't want to stop.
Go to "Start" - right click / properties
Goto "Task Bar" / Customize
It's there
Mel P
(thought I posted this once but it didn't appear!)
sfx said:
How are you going to stop your HDD's if they are ATA? They will not even show in there! :confused:
sfx
Both harddisks are there when I click the icon.
I just thought about it and it is the same icon as *** USB stick uses so I guess I can leave it if it isn't possible to stop the hardrives when Windows is in use.
I only got this icon on the taskbar because of my sata drives.
I haven't been able to find a way of removing the icon entirely from the taskbar, but the solution posted by Mel_P hides the icon from view.
They are internal SATA Hitachi drives.
I know how to hide the icon but I'd rather not use that function as I'd like to see what is running in the background.
If it isn't possible it's not a big problem, just one more icon that is on the screen.
