Saitek Cyborg R.A.T. Mice in stock!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
The Saitek Cyborg R.A.T. 3, 5 and 7 have all arrived today. The Wireless botty-kicking R.A.T. 9 is due at the end of the month. :)
Saitek Cyborg R.A.T. 3 3200 DPI Gaming Mouse @ £39.99 inc VAT
Sleek design, cutting-edge form factor and a host of programmable action buttons help you keep ahead of the competition no matter what the game.
- 4 Custom DPI Settings – Use the Rocker Switch to toggle between your custom DPI settings.
- 3 Programmable Buttons – Combine your Programmable Buttons with 2 regular left and right mouse buttons and give yourself a total of 5 buttons to punish the competition. Assign your choice of key gaming actions to Programmable Buttons to create your own custom profiles.
- 3 Cyborg Modes – Toggle between three individual R.A.T. modes at the touch of a button. Change sensitivity or Programmable Button actions in an instant and gain immediate access to a mind-boggling 15 commands!
- Powerful ST Programming Software – Change your DPI sensitivity, create custom profiles for each game, and assign commands to your Programmable Buttons. Easy, quick and the power you need right on your desktop.
- DPI range - 400-3200dpi (in 400dpi steps)
- Acceleration - Up to 10G
- Polling Rate - Dynamic up to 500Hz
- Tracking Speed - Up to 1.2m/sec
- Always On - Yes
- PTFE Slick Feet
- Gold plated connector - Yes
- Braided USB cable - Yes
Only £39.99 inc VAT.
ORDER NOW
Saitek Cyborg R.A.T. 5 4000 DPI Gaming Mouse @ £59.98 inc VAT
Step up to the flexibility of the R.A.T. 5 and come hunt with the big boys. Customize your R.A.T. to create a truly unique experience with a mouse that transforms and adapts to suit your needs. Adjustable Length – How do you hunt? Whether you ‘palm’ the mouse or ‘claw’ it, the R.A.T. can quickly and easily adapt by adjusting in length to suit your hand size and grip style. Custom Weight System – Like it light or heavy? Maybe you change the weight to suit your game? No matter, the R.A.T. has you covered. Five 6-gram weights can be added or subtracted in an instant, giving you the perfect weight for a perfect feel. When not in use, the weights can be safely stored in the supplied Weight Storage Container. Precision Aim Mode – Hit your target the first time every time. Use the ST Programming Software to set your desired Precision Aim speed (mouse sensitivity), then hold down the Precision Aim button to slow down mouse movement to a level that works for you. A deadly weapon that will hit your enemy where it hurts.
- 4000 DPI – Featuring a new-generation laser sensor with pinpoint accuracy, the R.A.T. 5 is truly ahead of the game.
- 5 Programmable Buttons – Combine your Programmable Buttons with 2 regular left and right mouse buttons and give yourself a total of 7 buttons available to punish your competition. Assign your choice of key gaming actions to Programmable Buttons to create your own custom profiles.
- Lightweight Metal Chassis – Strong yet nimble, the solid metal frame forms the core of the R.A.T. 5 for enhanced rigidity.
- DPI range - 125-4000dpi (in 125dpi steps)
- Acceleration - 30G
- Polling Rate -Dynamic up to 500Hz
- Tracking Speed - Up to 2.8m/sec
- Always On - Yes
- PTFE Slick Feet - Yes
Only £59.98 inc VAT.
ORDER NOW
Saitek Cyborg R.A.T. 7 5600 DPI Gaming Mouse @ £89.99 inc VAT
Play to win with the R.A.T. 7. Uncompromising, unparalleled, and unmatched, the R.A.T. 7 helps you play like the pros, combining state-of-the-art technology with a jaw-dropping array of customizable features to produce the next step in the evolution of the mouse. Perfect your grip – How do you hunt? Whether you ‘palm’ the mouse or ‘claw’ it, the R.A.T. can quickly and easily adapt by adjusting in length to suit your hand size and grip style. In addition, the Thumb Panel of the R.A.T. 7 moves forwards, backwards, and pivots outwards, giving you perfect positioning for effortless gaming.
- 3 Palm Rests: One featuring the same soft-touch finish as found on the body of the R.A.T., one with a rubber inlay for enhanced grip and one that is 4mm thicker to increase the height of the R.A.T.
- 3 Pinkie Grips: One featuring the same soft-touch finish as found on the body of the R.A.T., one with a rubber inlay for enhanced grip and one that offers a ‘wing shaped’ design, allowing you to rest your pinkie finger during play for increased grip.
- Custom Weight System – Like it light or heavy? Maybe you change the weight to suit your game? No matter, the R.A.T. has you covered. Five 6-gram weights can be added or subtracted in an instant, giving you the perfect weight for a perfect feel. When not in use, the weights can be safely stored in the supplied Weight Storage Container.
- Precision Aim Mode – Hit your target the first time every time. Use the ST Programming Software to set your desired Precision Aim speed (mouse sensitivity), then hold down the Precision Aim button to slow down mouse movement to a level that works for you. A deadly weapon that will hit your enemy where it hurts.
- 5600 DPI – Featuring a new generation ‘twin eye’ laser sensor that reads each axis separately for pinpoint accuracy, the R.A.T. 7 tracks up to a stunning 6 meters per second. Pro gamers who favor low sensitivity with high movement speed preferences will always experience correct tracking and precision.
- Powerful ST Programming Software – Change your DPI, set Precision Aim cursor sensitivity, create custom profiles for each game, and assign commands to your Programmable Buttons and Modes. Easy, quick and the power you need right on your desktop.
- Lightweight Metal Chassis – Strong yet nimble, the solid metal frame forms the core of the R.A.T. 7 for enhanced rigidity.
- DPI range – 25-5600dpi (in 25dpi steps)
- Acceleration – 50G
- Polling Rate – Dynamic up to 1000Hz
- Tracking Speed – Up to 6m/sec
- Always On – Yes
- PTFE Slick Feet
- Gold plated connector – Yes
- Braided cable - Yes
Only £89.99 inc VAT.
ORDER NOW
My girlfriend doesnt like my new MX518, would love to see her face if I set one of those on my desk :D
I have a rat 7 and its very very nice. Comfortable (and very adjustable if its not right for you).
The precision aim button is a god send in FPS games
First one looks pretty good to me tbh - has anyone tried one? Would be
interesting to find out the practicality of it
Tested one of them at work and found it utterly awful. The two buttons that are on the side I kept pressing constantly with the middle of my thumb, and the button on the left click was a nightmare also.
Prefer my G9 any day of the week :)
